True Position – Position Tolerance
Controls exactly where a feature must be located. Uses a circular tolerance zone and works with MMC — the most used symbol in GD&T.
Learn Symbol →
Datum Feature
A theoretically exact reference point, axis, or plane that other tolerances are measured from. Every controlled feature traces back to one.
Learn Symbol →
Profile of a Surface
Defines a 3D tolerance zone around any surface shape. One of the most powerful controls in GD&T for complex or freeform geometry.
Learn Symbol →
Maximum Material Condition (MMC)
Applies when a feature is at its largest allowable size. Can unlock bonus tolerance as the feature departs from MMC — often a significant cost saver.
Learn Symbol →
Flatness
Controls how flat a surface must be. No datums needed — it's self-contained, making it one of the simplest form tolerances to apply.
Learn Symbol →
Concentricity
Controls whether the median points of a cylindrical feature share the same axis as a datum. Expensive to inspect — position or runout usually works better.
Learn Symbol →
Perpendicularity
Controls a surface or axis at exactly 90° to a datum. Squareness has a formal definition in GD&T, and this is it.
Learn Symbol →
Runout
Controls surface variation relative to a datum axis as the part rotates. Measured at individual cross-sections — simpler and more common than total runout.
Learn Symbol →
Parallelism
Controls a surface or axis so it runs exactly parallel to a datum. Zero degrees is implied — no basic angle needed.
Learn Symbol →
Circularity
Controls how round a cross-section must be at any given slice. Applied independently at each cut — it doesn't control the overall cylinder.
Learn Symbol →
Straightness
Controls how straight a line element or axis must be. Can apply to a surface line or to an axis — and the difference matters more than most people realize.
Learn Symbol →
Total Runout
Controls the entire surface relative to a datum axis in one sweep. More comprehensive than circular runout — and harder to achieve in production.
Learn Symbol →
Cylindricity
Controls the entire cylindrical surface at once — roundness, straightness, and taper combined. Stricter than circularity, and harder to inspect.
Learn Symbol →
Feature Control Frame
The box that houses a GD&T callout. Every geometric tolerance lives inside one — learning to read it fluently is non-negotiable for GD&T.
Learn Symbol →
Symmetry
Controls whether the median points of a feature are symmetric about a datum plane. Like concentricity, it's rarely the right call — position is usually preferred.
Learn Symbol →
Angularity
Controls a surface or axis at an exact angle relative to a datum. Requires a basic angle dimension — it's the orientation call for everything that isn't 0° or 90°.
Learn Symbol →
Least Material Condition (LMC)
Applies when a feature is at its smallest allowable size. Used when wall thickness or material retention matters more than fit.
Learn Symbol →
Profile of a Line
Defines a 2D tolerance zone along any curved line or cross-section. Think of it as profile of a surface, but applied one slice at a time.
Learn Symbol →
Regardless of Feature Size
The default condition — tolerance applies regardless of the actual feature size. No bonus tolerance. Stricter, but sometimes exactly what the design needs.
Learn Symbol →
GD&T Rule #1: Envelope Principle
Requires that a feature of size have perfect form at MMC. It's a default rule in ASME Y14.5 — one every engineer should understand before drawing a size dimension.
Learn Symbol →
Unequally Disposed Profile
Offsets the profile tolerance zone more to one side than the other. Useful when stock removal or coating thickness shifts the functional surface.
Learn Symbol →
Independency
An ASME-only symbol that explicitly removes the envelope requirement from a feature. Allows form to vary independent of size — the opposite of Rule #1.
Learn Symbol →
Envelope Requirement (E Symbol) – ISO Only
An ISO-only symbol that requires the actual surface to fit within a perfect form envelope at MMC. Similar in concept to ASME Rule #1, but explicitly called out.
Learn Symbol →
Datum Target
Defines specific points, lines, or areas that establish a datum — instead of the entire surface. Used when surfaces are too rough or irregular to reference fully.
Learn Symbol →
Continuous Feature
Treats interrupted surfaces as a single continuous feature under one tolerance. Eliminates the need for separate callouts on each segment.
Learn Symbol →
Projected Tolerance Zone
Extends the tolerance zone beyond the feature itself — typically above a threaded hole. Controls where a fastener will sit in the mating part, not just the hole.
Learn Symbol →
Free State Symbol
Indicates a measurement taken without restraining the part. Critical for flexible or non-rigid parts that deflect under normal clamping.
Learn Symbol →
Restrained Condition Note
Specifies that the part must be measured while held in a defined restrained state. Used when in-service loads affect the measured geometry.
Learn Symbol →
Tangent Plane
Applies a tolerance to the tangent plane of a surface rather than the full surface. Useful when mating contact matters more than overall surface form.
Learn Symbol →
Counterbore
Specifies a flat-bottomed enlarged hole above a through hole. Controls the diameter and depth needed to seat a bolt head or fastener flush.
Learn Symbol →
Spotface
A very shallow counterbore used to create a clean, flat bearing surface. Common on cast or rough parts where a fastener needs a flat seat.
Learn Symbol →
Countersink
Specifies the angle and diameter of a countersunk hole. Commonly paired with a depth or diameter dimension for fastener seating.
Learn Symbol →
Diameter
Indicates the dimension is a diameter, not a radius. One of the most common symbols on any drawing with cylindrical features.
Learn Symbol →
Square
Indicates a square cross-section with a single dimension. Saves space on drawings when both sides are equal — one callout covers both.
Learn Symbol →
Radius
Defines a radius tolerance zone where the curve must fall between two arc boundaries. Allows slight waviness — use controlled radius when that matters.
Learn Symbol →
Controlled Radius
A radius with a smooth, fair curve — no flats or reversals allowed within the tolerance zone. Tighter than a standard radius callout.
Learn Symbol →
Spherical Radius
Applied to a spherical surface to control its radius. Works like a standard radius callout, but in all directions around the sphere.
Learn Symbol →
Spherical Diameter
Controls the diameter of a full spherical feature. The prefix S∅ distinguishes it from a standard diameter callout on a cylinder.
Learn Symbol →
Depth Symbol
Indicates the depth of a feature like a hole, slot, or counterbore. Replaces the word 'deep' on drawings — clean, compact, unambiguous.
Learn Symbol →
Dimension Origin
Shows that a dimension originates from a specific surface, not from the opposite end. Controls interpretation of tolerance stack in one direction.
Learn Symbol →
Parting Line
Identifies the dividing line on a part where mold halves or die sections meet. More of a manufacturing note than a geometric control.
Learn Symbol →
Arc Length
Indicates a dimension is measured along an arc, not as a straight chord. Used when the curved length — not the straight-line distance — is what matters.
Learn Symbol →
Conical Taper
Defines the ratio of diameter change to length along a conical surface. Gives a clear, single-value callout instead of two separate angle dimensions.
Learn Symbol →
Slope
Defines the rate of change of a flat tapered surface. Used on flat features the same way conical taper is used on round ones.
Learn Symbol →
Multiple Identical Features
Indicates a tolerance or dimension applies to multiple identical features. Simplifies drawings by replacing repetitive callouts with a single note.
Learn Symbol →
